EML to PST Converter
You can use this eSoftTools EML Converter Tool to import emails from any EML-compatible email client into Outlook. With the help of this one-of-a-kind tool, you can quickly convert multiple EML files to the PST format, which is supported by Outlook. It supports 9+ file formats for EML conversion, including PST, EMLX, MSG, HTML, MBOX, NSF, Office365, and Gmail. You can try out the EML to PST Converter sample edition for free to see all of its features. EML Converter's demo edition allows you to convert up to 25 EML files to PST or another format for free.
Read more:- EML to PST Converter
johnsheno
To convert EML to PST without losing any data, use the SYSessential EML to PST Converter tool. This software converts EML files to PST files quickly and easily. This software offers a simple and user-friendly interface that everyone can use. This program is also available in a free trial version. and It Supports MS Outlook 2019, 2016, 2013, 2010, 2007, etc.
WholeClear EML to PST Converter Software is the safest and most effective tool to import EML file into PST format . They are compatible with MS Outlook versions 2019, 2016, 2013, 2010, 2007 for Window. This software has an update feature that user can use preview recover data before saving it. EML files of every email client are well considered by the utility which includes Windows Live Mail, Outlook Express, Mozilla Thunderbird, IncrediMail, and others. EML files created by any EML supported email client can be quickly converted into PST format by this utility.
Toolsbaer EML to PST Conversion Tool offers error-free data migration. The application gives you no reason to complain because it exports data seamlessly. All email properties are exported including CC, BCC, too, and from. The exported EML files save in PST format and at the user’s specified location. It could be any suitable location in the system. If you are interested in the utility, you can consider its free demo version.
Key Features of the Tool
No file size limitation
Bulk conversion facility
Allows to convert selective files
Supports all Windows & Mac editions
Maintains all the properties
