EML to PST Converter
If you need to convert an EML file to PST file, use reliable software such as eSoftTools EML Converter Tool. It converts all EML files from various email clients, such as Windows Live Mail, Apple Mail, Mozilla Thunderbird, and Outlook Express, to the Outlook PST file format. This software converts EML and EMLX to PST and allows you to convert multiple EML files to PST. It extracts all of the important email components, such as To, Bcc, Cc, Sent, From, Received, Attachments, and so on. The software PST files are compatible with all versions of Outlook.
Get more info- EML to PST Converter
You just need to use this professional EML to PST Converter tool, with the help of this tool the user can easily convert their Windows Live Mail EML files to Outlook PST file format. This tool has a preview option for the mailbox items before saving them to the user-defined location. It has a free version, so the user can check the accuracy of the tool. The tool is compatible with Windows 10, 8.1, 8, 7, Vista and Windows Server 2008, 2003 versions. For more details visit: https://www.datarepairtools.com/windows-live-mail-to-pst.html
