Eraser 5.7 on WinNT 4.0
  • Start date Start date
Far as I can tell, Eraser 5.7 seems to be working fine on the WinNT 4.0 comp I use it on at work, but when I go to remove Eraser 5.7 near the end of my shift, how can I be sure that the program itself is gone completely? I'm concerned that the usual bi-annual hard drive exam (by an outside company) will detect Eraser 5.7's deleted files if they look for files that have been deleted but not wiped and it'll look awfully suspicious if it's found that someone on my shift has been using a program that wipes deleted files. Someone please reply a.s.a.p. to Rufinoform@aol.com Thanx!
Take care! Hope to hear from you soon! Wuff!
Cloudchaser
<img SRC="http://www.cloudchasershaconage.furtopia.org/wolfwink.gif" height=34 width=49>
