I have searched the forum,red the FAQ but wasn't able to find a solution/tip to help me solve this small issue.
Is there a way to display icons in the "general" (files/folders) Explorer context menu of Eraser 5.8.8 ?
(which is running on an old laptop requiring old applications to run smoothly - newer version of eraser are too heavy/slow for this machine).
In 'General' it is possible to activate/deactivate the Shell extension but no Icons are displayed on the context menu (only the 'Erase' & 'Erase Secure Move' texts)
In the context menu of the Recycle bin I was able to add an icon to the Eraser entry by specifying in the registry
"Icon"="<path_to_icon>,0"
under
[HKCR\CLSID\{xxxx}\Shell\Erasext1]
(have removed all unnecessary recycle bin Eraser entries)
but I can't find any place where the same can be achieved for the "general" Explorer context menu of Eraser (when you right click a file/folder).
Any help would be greatly appreciated.
Thanks in advance.
under
Thanks in advance.
