Eraser 5.85 Beta 6
Status
Not open for further replies.
FlyingHorse said:
Joel said:
Please bug this.
It will help if you can tell me where these files have been installed to:
Eraserl.exe
Eraser.dll
Eraser.exe
Verify.exe
Erasext.dll
Give me some time to uninstall 5.84 and re-install 5.85 and I'll get your information.
Thank you for taking the time to help. :)
@Joel
Here are where the files land on Vista x64:
Code:
Eraserl.exe -> C:\Windows\System32
Eraser.dll  -> C:\Windows\System32
Eraser.exe  -> C:\Program Files (x86)\Eraser
Verify.exe  -> C:\Program Files (x86)\Eraser
Erasext.dll -> C:\Windows\System32
The MSVC++ 2005 (x64) Redist. was properly deployed.
HTH
So all files went right except the eraser.exe and verify.exe? Sorry I don't use x64 and don't have much idea how Windows does its thing...
Hi ogy73
Do you mean Eraser version 5.85 Beta 6 ?
Also could you run check disk and then try again,
Thanks.
Overwriter said:
Hi ogy73
Thanks.
Hi Overwriter and Thanks.
Yes it is 5.85 beta 6.
I will run a chekdisk soon posible and see what happens.
Sorry for my bad English.
Wasn't the recycle bin error fixed already? What is the error message for failing?
Check 5.86 RC 1 to see if your 64 bit thing has been fixed as well as the recycle bin issue.
Status
