Eraser 64Bit Alpha Release
Why release the alpha to 64 bit without that one to 32?
The great part of the windows systems is still to 32 bit...
1 year of attended for this?
Roflast... :lol:
Good bye new version of Eraser!
We needed to see if major changes would be required in migration and because the shell extensions have to be 64bit on win64.
All research on the new version of eraser is in Delphi and there will be no 64bit version of that compiler for another year. Thus no right click 'erase'
Garrett
Garrett
Since Borland won't release their 64 bit compiler for awhile, have you guys looked into using Free Pascal from http://www.freepascal.org/ to compile the Delphi/Pascal source code?
X64
Recently downloaded and tried Eraser on a X64 pc.
Does not work.
It appears that the version I downloaded from the Eraser Support Forum under the Eraser 64Bit Alpha Release announcement (http://www.heidi.ie/download/eraser58setup.zip ) is the same as the version in the Eraser 32bit download area. Is this correct - or there a different X64 version?
rbd
