Eraser and Sharepoint 2010
chahrour
Hello,
I want to know if it is possible to integrate Eraser to Sharepoint 2010.
In addition, i want to know if it is possible to define automatic rules for deleting data from the Sharepoint library?
The automatic rules I want to define is about : delete folders depending on their creation date, delete a file depending on its date of creation, delete folders after a certain delay, ...
thank you in advance for your response
IIRC, SharePoint uses a SQL server for its backend. Deletions would be SQL DELETE commands which modify an opaque data file (Microsoft has not documented the format)
This would make it impossible for Eraser to do it's job... you're out of luck for this one, sorry.
