Eraser Configuration Won't Save
Sebz
I've tried several times to change the listings in the 'replace erased files with the following' area of the settings and it just won't save.
I have a folder listed in there that has been deleted, so when I try to erase ANYTHING it errors that this folder is missing and it cannot perform erases.
Uninstalling and reinstalling didn't work. :(
Where is the configuration located, so I might try to manually remove this entry?
THat's a bug in the stable v6 (6.0.6.1376), fixed in the nightly branch of v6.0.
