Eraser does NOT erase items with overlong path+filename
pstein
As I found out Eraser v6.2 does NOT erase files with an overlong path+filename (>259 chars).
These files exists after a move or backup of directory trees into another subdirectory.
However the path+filename length is not absolute limit (in Windows 10). There a lots of programs which can handle them.
Can Eraser add a support of such files with overlong path+filenames into next release?
Possibly Eraser could (as a workaround) rename at first the file to a shorter name like a.txt and then erase them
Thank you
