Eraser for DOS?
asjones
I was wondering if anyone could expand on the features in Eraser for DOS eraserd.exe?
What command line opitions and features are supported?
I can see using it in batch files or called from scheduler to run and erase predefined things in the middle of the night. Like erased these directories call from a command line (cache, recycle bin, etc) or wipe free space, etc....
I have concerns about installing all of Eraser and the context menus etc. If eraser for DOS was powerful enought it might be nice to make that a seperate download along with the DBAN utility.
thanks for the help.
Alan
If you wish to use a command line interface on Windows, you should use eraserl.exe instead. For details, see the help file.
