I have downloaded 6.0.7 and when I try to run the program it givec me this message. program does not have permission to delete unused space. I have set it to run as administrator whith no luck.
Did you close the running instance of Eraser before starting to run as Administrator? Right-click on the tray icon, select 'Exit Eraser', then run from the desktop icon as Administrator.
