Hi, I'm have an ongoing problem with Eraser (current version 5.8.2.0). This has happened on other PC's I have had and with earlier Eraser Programs (XP SP2). When wiping the drive of all unused disk space, there is the option to shutdown the system when finished from the properties of the listed task ('erase all unused disk space on drive c'). I always keep the task on the list, check the properties to ensure the option is ticked and it never works! I've tried everything to no avail. The shutdown option is gone after the wipe is finished too which makes it even more confusing...
Also, I have no background programs running (after using msconfig), I have full administration rights and at the end there are many files in the report which were not able to be wiped due to being protected?? Is there a way around either of these issues? Please let me know.
Thanks...
Thanks...
