I have set a schedule up to delete all the contents of TEMP, Recent, Temp Internet, and Cookies folders. This helps keep my system clean.
When there is a Virus in the 'Temp Internet' folder (TEST VIRUS), Eraser triggers the Anti Virus because it thinks Eraser is trying to open the virus, then Eraser can't complete it's tasks.
I'm forceed to delete the old fashion way, then manually run my script again.
Any thoughts on this?
Also for deleting index.dat and History.IE5 etc:
For NT Kernal Systems:
All you need to do is setup another account, log on to that and run your script from there. Because your system isn't using those folders, you'll be able to delete them. Then log back in to you normal account.
Then when I log back in, Eraser tells me that there isn't anything to delete. With this error message, I know that my script has done it's job.
Cheers!
Cheers!
