Erasing Recycle Bin hangs-up
luca62
Hello everybody,
I am using Eraser 5.86.1.
Sometimes, it seems that Eraser got stuck in some "infinite loop" :shock: while erasing folders (containing files) into the Recycle Bin.
Even pressing the "Stop" button, while closing the UI, doesn't terminate the underneath OS process -- by the way, it can't be killed neither by way of the Task Manager nor using, for instance, the Sysinternals Process Explorer.
Even the "Restart" takes minutes to be responsive. :roll:
Any idea ? Thanks in advance
-luca-
It looks like this and I can't find a reliable way of resolving it. Eraser 6 however should not have this problem.
