Erasure Methods
Tc_guy
Can Eraser 6.08 be setup to overwrite unallocated space with user-configurable data? I'm doing some testing and I want to be able to overwrite free space with a specific bit pattern (all 0's, all 1's, alternating 0's and 1's, etc.).
Forgive me if I've missed it, but all I can see in the options is a list of predefined algorithms.
Thanks.
Go to the Settings page, scroll right to the bottom, right click on the Default Plugin. There's a context menu that allows you to configure the plugin settings. On the dialog that opens, a tab is dedicated to customising your own erasure methods.
I designed the editor to be much more powerful than the v5 editor, hope it works well for you.
