I will suggest to you a better option to recover the 7zip password without any difficulty. If you want a perfect solution then try eSoftTools 7z password unlock that quickly recovers any complicated 7zip password using AES algorithm. It will help you to recover a 7zip password and save it directly into a clipboard or text file. This software does not modify the internal data and also removes any long password including alphabetic, numeric, symbolic, and special character password.
Get More Info- 7z Password Unlocker
