eSoftTools NSF Converter Tool
Download eSoftTools NSF Converter Tool and quick to migrate NSF emails, contacts, calendar, to-do list and all other folders and sub-folders to MS Outlook supported PST file as well as MSG, EMLX, EML, MBOX, HTML, CSV, VCF and ICS file. This software supports to convert unlimited size of IBM Lotus Notes database files and supports all versions of IBM Notes including 9.1, 9.0, 8.5, 8.0, 6.5 and others.
Try demo version software for quick evaluation and test to convert 50 items from every folders and sub-folders.
Get the demo software from - https://www.esofttools.com/nsf-to-pst-converter.html
Bitdataconversion NSF to PST Converter is a professional tool which makes conversion task very easily. It’s a truly incredible solution for all users to convert or migrate multiple NSF files to PST, EML, and MSG without any interruption. It supports all versions of IBM Notes, Outlook, and Windows OS. Download its free trial version and migrate the first 50 items per folder.
For more details, visit - NSF to PST
GainTools NSF to PST Converter Tool is the one that is efficient, and can switch a large number of files and with great speed. This is frequently the case with the less known applications. Henceforth we requirement software like NSF to PST Conversion which is precisely what a migration application should do. It has all the potentials of a good NSF to PST Utility and also has a free demo for those who want to see for themselves.
You can effortlessly convert NSF to PST file-free by utilizing the best software known as Softaken Lotus Notes to Outlook converter software. It can convert single or bulk NSF files to PST files without losing any data. It can also perform the batch conversion in which users convert NSF files to PST or other formats like PST, HTML, MBOX, EML, and EMLX. It can also support all editions of Windows operating systems up to 10. It can also offer a free demo in which users can convert the first few items of NSF to PST files.
Recently, I converted NSF files to PST files with the ToolsBaer NSF to PST Converter Tool; this application is safe and simple to use, therefore you should try it. It also gives free demo versions for testing and analysis. It is an expert solution for precisely converting NSF files to PST format. It smoothly converts NSF files to Outlook PST format with no data loss. NSF files can be opened as Outlook PST files in all versions of Microsoft Outlook. It is internationally compatible with all versions of the Windows operating system, allowing users to run it on any Windows operating system. There are no file size limits while converting NSF data to PST format.
