eSoftTools OST to PST Converter
eSoftTools OST to PST Converter is one of the best emails conversion tool, that can convert inaccessible OST file data into PST. This tool is made up with highly advanced algorithm and highly advanced features.
• The OST to PST converter also help to recover your corrupted OST database.
• Maintains the Folder Hierarchy and Mail Properties to get preserved
• All the properties of the mail such as bcc, to, cc, date, subject, time, etc. gets stored and not just that but the status of the read and unread mails are kept intact too in a very structured format.
• Offers you a benefit that you can access multiple folder with the help of single click
• Export OST files in to PST, EML, EMLX, MSG, vCal, vCard, MBOX and HTML.
• Compatible with all the version of MS Outlook 2019, 2016, 2013 and all the below version.
Read More Info:
SysInspire OST to PST Converter Free Download Tool is best software to import OST to PST Outlook and open it within minutes. While using this software, you can see the preview of each OST mailbox items. This software has comes with more than 8+ conversion options which give you flexibility to convert OST emails to different-different email clients. The conversion options for OST file are – OST to PST, EML, MBOX, MSG, EMLX, CSV, ICS, VCF, HTML and OST to Office 365.
Best deal at sysinspireOST to PST Converter Software for
convert OST file to PST
The recovery process of the Exchange OST database is easy if you use the OST to PST Converter application that is composed using the rich algorithm and the best technology. Using it, you can simply recover data and convert it to the newly created Outlook PST file format without any difficulty. The auto scan feature of this program deeply scans the OST file and converts all data into an Outlook PST file.
This application has a GUI that makes it easy for everyone to use. It is compatible with Live Exchange Server version 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016. It is compatible with versions 95, NT, 98, ME, XP, Vista, 7, 8 and 8.1,10 of the operating system Windows (32 bits and 64 bits).
Before finalizing the conversion, it shows the preview of the recovered mailbox along with all the data such as email, draft, task, attachment, notes, contact, sent item, deleted item and many more. The user of the MS Outlook email client easily exports Exchange OST data to PST, EMLX, EML, MSG, HTML, MBOX, vCal and vCard file formats without wasting any more time.
It has many features that make the conversion process fluid and reliable. To evaluate this work, you can return it in less than 30 days.
Check out more info visit from:
https://ats-ost-to-pst-converter-toolkit.en.softonic.com/
Yes, I would like to advise you to effort extremely latest and professional GainTools OST to PST Converter File Software in economical price. With the help of a tool you can quickly and securely convert the OST file into Outlook PST and other appreciated file formats such as EML, MSG, MBOX, HTML, and VCF file formats. It gives approximately latest features just like you can Split your large PST file into small PST file. It is workable with Microsoft Outlook version 97, 2000, 2003, 2007, 2010, 2013, 2016, and 2019 it also supports all Windows versions just like 10, 8, 7 and Vista.
The non-technical users can securely perform the conversion with the help of KDETools for 100% free ost to pst converter tool which is the great option for the convert ost to pst in outlook 2016 online file format without any problem on Windows system. The unique technology can smoothly run in all updated versions of the Windows OS and also supports all the email clients for many file formats such as- Zimbra, Gmail, vCard, ICS, MSG, EML, EMLX, Office 365, Live Exchange Server, and etc. MS outlook offline OST mailboxes consist of several items like emails, tasks, notes, journals, and more into new Outlook PST files. The software provides secure and complete risk-free conversion of data. The utility also supports all MS Outlook versions.
Easy Method-: Export/ Import From Corrupt Offline OST to new Outlook PST file format-
  1. Open Microsoft Outlook 2019, 2016, 2013, 2010 or previous version.
  2. Remove Navigate errors, corruption issues.
  3. click PST 'File' menu and select 'Import & Export'
  4. This will open 'Import and Export ', select 'Export to a File'
  5. Further, select 'Outlook data file'(PST) format from the given storage options.
More Info- How to Convert OST to PST Outlook 2019, 2016, 2013, 2010, 2007
Use the OST to PST Converter utility and easily convert your OST document to PST, EML, EMLX, MBOX with email residences, including attachments, tasks, notes, journals, calendars, zip attachments, and embedded photos. In addition to some emails, you can also convert individual emails to different formats by helping all MS Outlook versions 2019, 2016, 2013, 2010, 2007, etc.
