Exchange EDB file viewer tool
If you are finding the best tool for EDB Conversion then try this eSoftTools EDB to PST Converter Software, converting EDB to PST can be very easy. The Exchange EDB file viewer tool will restore details from the mailbox and then display a sample in a readable file format to the recipient. Since it allows selective migration, the user must first pick the EDB file and then the mailbox objects for transfer.
Get More Details Here:-
Exchange EDB Recovery Tool
