Exchange OST to PST CONVERTER Software
If you don’t know how to convert inaccessible OST file into PST format then I want to suggest an amazing and reliable Software PDS OST to PST Converter. It has too many amazing features like – Multiple Naming Convention, Convert Encrypted OST file etc. The best feature about this Software is it made use of advance algorithm which also helps non IT users also convert their corrupted OST file. This Software provides to save converted OST file in other multiple formats (EML, MSG, MBOX, HTML, PDF and Office365).It’s also provides free demo version for all users.
Read more: Free to Convert OST to PST by using OST to PST Converter
OST to PST Converter tool to have all the features that you want in one converter. This software can export your data into PST, EML, EMLX, MBOX. To know more about this tool you can use the free demo version of this utilit. With the help of this tool, it can be easily work on MS Outlook versions like 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016, 2019 (32bit & 64bit), and also on various latest platforms. You can try the free demo version of the converter to convert 10 emails for free.
camilia
In addition to this, I would like to suggest a one more alternative i.e. OST to PST Converter software . This Software is helpful in doing the OST to PST file conversion safely. This tool is much affordable and more features as compare to others.
The conversion tool to convert OST files outlook format included 14 plus file formats according to you such as- PST, Zimbra, Gmail, EML, EMLX, vCard, ICS, MSG, Office 365, Live Exchange server, MBOX and etc. Download and try its free version and convert 30 emails freely from OST to PST outlook format.
• Batch Conversion option.
• Split option.
• Export all the folders of the file extension
• Maintain data integrity and properties
• File size is not an issue to get satisfactory conversion results
• Integrate with MS Outlook 2003, 2007, 2010, 2013 ,2016, 2019.
more info- OST to PST Converter
tomhayden
GainTools OST to PST Converter App is a useful explanation for those users who would like to convert the data from OST file to Outlook PST file format. Trying it you can migrate all the data of OST file like emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). It gives you the ability to see the preview of the move mailbox before finishing the exporter. This utility has lots of saving formats that store the subsequent file such as PST, EMLX, EML, MBOX, MSG, vCard, vCal.
