Exchange to Office 365 Migration
Ethankoles
Microsoft handles updates automatically, which means clients no longer have to worry about updating and maintaining a server. Therefore most users migrate towards Office 365. If you are considering Exchange to Office 365 migration task, you can execute it manually and professionally. Manual migration is complicated, whereas the professional method is more accessible and straightforward. The best tool to execute Exchange to Office 365 migration task is Shoviv Exchange to Office 365 Migration Tool. The user-friendly GUI of the software makes it easy for non-technical users to perform the migration.
There is no bar on adding several mailboxes. Hence users can add multiple and large-size mailboxes in a single process. With an option like Filter, you can exclude unwanted data and include the desired one. The software consists of an Incremental feature that resumes the task from the point where it was last ended and prevented data from duplicating. The software is compatible with Windows O.S. and Exchange Server. Users can select the mailbox from the folder view to preview their data. The software does not alter the original data and hierarchy of folders.
You can try the tool before buying, as the software provides a free demo version and allows you to proceed first-fifty items.
Do you need a free application to transfer Exchange mailboxes to PST? We've introduced the expert EDB to Office 365 Converter software, which allows users to easily export mailbox EDB files to Office 365 file formats for free. Users can export a limited number of EDB files for free in the trial version.
But it also offers a lot of sophisticated capabilities, such as the ability to export offline EDB files to Office 365 and Live Exchange. Also, it converts EDB files gradually into several file formats. It offers a full glimpse of the relevant data when it converted your single or numerous EDB files to Office 365 at once.
You may use it to scan EDB mailbox data objects. Also, it continues to convert files in their original formats while storing them during EDB Conversion. The large size of EDB files can also be exported without producing any issues.
