The eSoftTools EDB to PST Converter is compatible with all versions of Outlook even Outlook 2016, Exchange, and Windows.
To Export EDB to PST Exchange 2016, follow the below steps to convert EDB to PST:
● Launch the eSoftTools tool and select offline EDB as the source type.
● Select the EDB file that you want to convert.
● Select the specific scanning mode to scan the EDB file.
● Once the EDB file is added to the tool and select Export Mailboxes to PST.
● Now, choose whether you want to create a new PST file or convert the data to an existing PST file.
● Select the certain filters if any you need to suggest on, and then click OK.
Read More Details:- Export EDB to PST Exchange 2016
