Export EDB to PST
I would like to recommend you use this SysInspire EDB to PST Converter software which has a highly advanced feature to convert offline EDB to PST or any other formats like EMLX, EML, MSG, and HTML. This software converts Mailboxes from priv1. edb file and pub1.edb file to Outlook PST file with maintaining all email properties such as from, to, bcc, date-time and subject. It can easily run on all Exchange servers and MS Outlook versions from 97 to 2016.
Get More Details:- Export EDB to PST
You can finish the EDB data conversion very fastly and very easily with SysOZ EDB to PST Converter. It has a free demo version facility to export the 30 emails per folder free of cost. You can convert your data into various formats like PST, MSG, EML, and HTML. You can also avail the 30 days money back policy, with this converter you can also avail 24X7 customer care support. You can also split the large sized PST files into various small bits as per your needs. The size of the EDB file does not matter for the conversion.
Read More: SysOZ EDB to PST Converter
