Use this superb application derived by SysInspire named as Free EDB to PST Converter software. The software can work without the Exchange server but remember MS Outlook is required to run. The user can make Exchange mailbox recovery EDB to PST by maintaining all email properties and every structure of the folders. Users can also use the splitting feature to shorten any large PST file into small PST files.
For More Info:- Export Exchange Mailbox to PST
If you want to convert online and offline Exchange EDB file to Outlook PST format. You can try this advanced EDB to PST converter tool which can easily convert Exchange EDB files to multiple formats like PST, HTML, RTF, MSG and EML. It can also move your offline EDB data to live Exchange and Office 365 mailboxes with ease. The tool supports all versions of MS Exchange for converting. To get more information about this tool, visit: https://www.datarepairtools.com/edb-to-pst-converter.html
MS Outlook is used to save all emails and other items to the EDB file, and if the server goes down and you can't access your files, you'll need to use a third-party solution to recover the EDB file. So I would recommend you use this eSoftTools EDB to PST Converter software, which is a powerful application that can convert EDB files to PST files with all email attributes intact, such as emails, appointments, diaries, connections, schedules, notes, tasks, and so on.
To Know More:- Export Exchange Mailbox to PST
To export Exchange mailbox to PST try the Advik Exchange Server Backup Tool on your system. The software will effortlessly convert the complete Exchange mailbox to your PST file without any hassle. This powerful tool ensures the data integrity and mailbox folder hierarchy as well during the process. It provides various advanced filter options to export selected data from Exchange mailbox to PST file.
