Export Lotus Notes to Outlook using eSoftTools NSF to PST Converter
Recover and convert lotus notes emails, contacts, calendar, to-do list, and other files quickly and perfectly with eSoftTools NSF to PST Converter Software. This tool is developed for the purpose of resolving NSF convert to PST Outlook file with all information. This NSF Converter software also has inbuilt feature’s to split the PST file from a larger NSF database. All the converted PST files are in Unicode format for maximum Outlook version supported. Do your NSF Conversion task completed with the use of a single NSF Conversion Toolkit and save all mailboxes information.
Get more info: Export Lotus Notes to Outlook
Move the data from Lotus Notes to Outlook email client by transferring there file extensions from NSF to PST format without any hassle. To transfer the data from NSF to PST you can use the NSF to PST Converter software which is a great solution for the migration of the data. To know more about this software you can visit here:- https://www.softaken.com/nsf-to-pst-converter
