Export NSF mailbox to PST with eSoftTools NSF to PST Converter
Without installing Microsoft Outlook application eSoftTools NSF to PST Converter Software converts multiple NSF files into MSG, EMLX, EML, MBOX, VCF, HTML, ICS. vCard and CSV file formats. This software shows NSF file conversion results in a single click in a secure way. To convert NSF file, the software has not any kind of limitation like on size & quantity and while converting the NSF file. It performs 100% secure conversion and has the great feature to export Lotus Notes NSF files to PST in bulk by applying batch process. It works with all Outlook versions as well as runs on all Windows OS up to 10 including 32 & 64-bit. Download this tool to take the advantage of it's free demo edition to convert 25 items per folder with all MS Outlook versions up to 2019.
Visit here:
For the email data conversion from NSF to PST format the user can take help of NSF to PST Conversion guide through which you can gain knowledge to migrate the data safely and in accurate manner. This blog gives you the great experience and hassle free transition from the any size of NSF file into PST format.
