Export NSF to PST with NSF to PST Converter
eSoftTools NSF to PST Converter is updated with advance algorithms to recover corrupted or harmed NSF files in to PST. This NSF Converter preserves the email components like drafts, attachments, journals, tasks, calendars, and contacts.
* No requirement of Outlook installation
* Export NSF files in to various file platforms PST, EML, EMLX, MSG, HTML, MBOX, ICS, VCF and CSV file.
* Perform batch process in just one click
* Split large size NSF file
* Supports all Lotus Notes versions including latest version
* Date filter feature to search for the specific NSF location
* Compatible with all editions of MS Outlook up to 2019
Visit here -
Export NSF to PST
If you want the reliable and easiest way for the NSF to PST Conversion, I would suggest, go with the third-party tool, Bitdataconversion NSF to PST Converter Tool. The tool provides the best and error-free conversion and easily converts multiple NSF data to Outlook PST within a few times. Download its free trial version and convert the first 50 data items per folder. It also provides free technical support 24/7.
For more details, visit - NSF to PST
To access the data of NSF file of Lotus Notes into Outlook email client the user need to transfer that files into Outlook PST from Notes NSF format. You can perform the conversion of data from Lotus Notes to PST simply by taking help of the data conversion manual for NSF to Outlook PST. It will help you in migrating the files safely and instantly. It explain whole process of conversion of the Lotus Notes NSF files.
If you are searching the pre-eminent quantity of Software online to convert NSF to PST which gives you the complete conversion of data from IBM lotus notes to MS Outlook then try eSoftTools NSF to PST Converter Software will include all items such as- contacts, emails, calendars, task, notes, inbox items, journals, and appointments. It smoothly recovers the lotus notes NSF file and restores all NSF files to Outlook, EML, MSG, HTML, EMLX, MBOX, vCal, ICS, vCard, and many more formats. The software supports all lotus notes versions version upto 10.
Read More - Export NSF to pst file
