Export PST to MBOX
camilia
If you want to convert your PST to MBOX Thunderbird then you can use KDETools for PST to MBOX converter software which has simple working steps to fix pst files “errors, corruptions, and etc. This is a very good solution provided for converting and imports multiple PST files in the Windows MBOX Thunderbird file format with Zimbra, vCard, ICS, MSG, EML, EMLX, MBOX, Office 365 account, Live Exchange Server, and etc.. This software is compatible with all the versions of Windows OS & MS Outlook and other related email client.
More info- Export PST to MBOX
Quickly export PST to MBOX with the help of Softaken PST to MBOX Converter Software that is perfect solution for all average users. This software has the capacity to export multiple PST files along with mailbox objects. It comfortably maintains the folder and sub-folder hierarchy. The utility does not need Outlook application installation for migration. You can any size of PST files to MBOX without modifying the internal data.
It looks like you are searching for a tool to export Outlook PST emails to MBOX. PST to MBOX Conversion is now a very easy Process by Using this PST to MBOX Converter for Mac Software where you can easily migrate your PST file into the MBOX file. The tool will offer smooth migration of Outlook data from PST to MBOX. You can then import MBOX in supported email clients. PST mailboxes consist of several items like emails, tasks, notes, journals, and more. The software provides secure and complete risk-free conversion of data. It also supports all MS Outlook versions.
