Hi,
I am not a computer expert, so please bear with me. I have been successfully using Eraser 5.86.1 on Windows XP for some time now, but recently I have been getting an error message after my clean disk command:
"Failures:
Failed: C:\~ERAFSWD.TMP\63KA02E8.312"
Otherwise, it appears that the erase has worked (although I can not tell since windows tells me that it is already deleted). Afterwords, I can not find the file ~ERAFSWD.TMP anywhere on my system. Is there something I can do to prevent this error?
Thanks,
DavidBear
"Failures:
Thanks,
DavidBear
