Hi,
it would be very nice if eraser would show a pop-up-window before delating. In this pop-up-window should be an option to select the erasing method.
If I start eraser and put some files to be delated in the programm I start the erasing process and I reconise often that the erasing is on the false erasing method because I forget often to change the erase settings. It would be very comfortable to have such a pop-up-window with this function to change the erasing method directly before delating. Thank you for such a nice software.
