Famous Exchange OST to PST Converter
One of the famous Exchange OST to PST Converter Software that can easily repair damage / corrupt OST file data within few minutes.
Deeply scan: The auto scanning process of this tool deeply scan the file and fetch all the flaws then remove them instantly.
Convert single and multiple files: Using it the user can export single as well as multiple files in at a one time.
Show the preview: Before the conversion, it shows the recovered mailbox along with all the properties of emails such as To, Cc, From, Date, Time, Object, Subject and Bcc.
Supporting Version: It support all the version of MS Outlook such as 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019 and the OS Windows version 95, NT, 98, 2000, ME, XP, Vista, 7, 8, 8.1, and 10 (32 bits & 64bit).
Saving Formats: After the conversion, you can store your data into several file formats like PST, EML, MSG, vCal, vCard, EMLX, and MBOX.
Support cloud-based application: It supports cloud-based application Office365 & Live Exchange Server.
Use OST to PST Converter to convert OST file to PST format in a very simple way. This software easily transfers all OST file data to PST format without any data loss. OST to PST Software can convert multiple file format options like PST, EML, EMLX, MSG, MBOX, and VCard formats. A free demo version of this software can also be used to convert up to 10 items per mailbox from OST to PST format.
