Fast and Safe OST to PST Conversion Tool
InQuit OST to PST Converter is specially design for Outlook client who faces problem with MS Outlook mailbox on cache mode or down Exchange Server. One of the best user-friendly software which can easily works with MS Outlook on down Exchange Server to easily restore emails from unreadable OST file. As you know that OST files are carbon copy of Outlook emails on down Exchange Server which is stores in client machine but Outlook users cannot open without third party OST Recovery software. You can convert the data into various formats like EML, EMLX, vCal, vCard, MSG, PST, MBOX etc. Avail the demo version of the converter so that you can convert 30 emails for free.
OST to PST Exporter process is very simple to perform and achieve successfully by using the OST to PST software that can automatically convert your OST files to PST files. It can recover all corrupted OST file to PST Outlook data without any issues facing. It supports all MS Outlook version like:- 2003, 2007, 2010, 2013, 2016, 2019 etc.
OST to PST converter process is very easy to perform and achieve fruitfully for converting email, mailbox from damaged OST to PST outlook with [Attachments], Office 365, Gmail, G-Suite, Exchange Server, MBOX, MSG, EML, Office 365, Exchange Server, and etc..
Best key-features of OST to PST Converter Tool-
• Batch migration Option.
• Divide the large size of OST files into small PST files.
• Supports all Windows OS.
• Export bulk OST to PST Outlook file formats.
more info- OST Converter - Convert OST to 10+ File Types
If you want to recover data from corrupted OST file so you can download OST Recovery application that migrates entire OST data into Outlook personal storage table ( PST) file. You are able to do work on the offline mode by using this application which has unexpected features to recover OST data.
This device designed to recover entire data in a perfect manner. This software work with all the version of MS Outlook as well as Window server version like 2003, 2003 R2, 2008, 2008 R2, 2012, 2012 R2, 2016 effortlessly.An additional feature is also available to save your PST file for future use which known by this name cloud-based application Office 365 & live Exchange server.
You can save all properties of mailbox like Emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes and metadata property to, cc, bcc, subject, date and time. There are several formats which save your OST file data along with all emails and attachment into PST, EML, MSG, MBOX, HTML, vCal, vCard, and EMLX file format.
The users can export 30 emails from each and every folder free of cost in its free demo version. If you are not happy with this tool then you will be able to return it under 30 days.
