Fix Errors in MS Outlook .OST to .PST file enables you to export OST to PST along with mailbox components like emails, tasks, drafts, calendars, journals, and contacts. This OST to PST Converter export the selected OST file data in to Outlook PST, EML, EMLX, CSV, VCF, HTML, MBOX, etc. The software can perform batch migration of Exchange OST Mailbox and apli the huge size OST files in to multiple PST files.
Visit here - Export OST to PST
tomhayden
GainTools OST to PST Exporter Application is a complete resolution that supports to migrate data from OST files like calendar, address book, draft, notes, meeting, and task to Outlook PST. User can saves the OST files in numerous formats such as MSG, EML, MBOX, PST etc. The Conversion has the capability to export Address book in numerous formats like PST, MBOX, EML, MSG and VCF file in a very short time. This utility effortlessly supports all versions of MS Outlook, & Windows.
If you want to convert your OST file to PST file format than I suggest you to use OST file conversion tool to Convert OST to PST file format. by using this utility the user can easily migrate the OST file data to Outlook PST file format. The user can easily export emails, contacts, and calendar, Etc. If users have any questions then they can simply contact to our support team which is available 24*7 to guide users.
camilia
Try OST to PST Converter software to convert OST to PST Outlook format. Its application save emails, mailbox from OST to PST Outlook including all attachments. It also lets the users convert the first 30 items per folder. Through the full version of this tool, users can fix OST files errors. This utility easily transfer unlimited OST files and save them into Outlook PST file, Office365, Exchange server, vCard, EML, EMLX, MSG, Gmail, Zimbra, MBOX and etc.
More info- OST to PST Converter
