margkerberg
Have you tried any method to fix OST corruption issue? If yes and the method does not work then this ATS OST Recovery software is for you only. This is the best conversion tool that allows the user to import their data into Outlook PST file format. If your files are heavy in size so don’t disturb because this software has a split option which divides your Large OST file into several small PST file formats. This tool serves a free demo facility to convert OST data into PST, MBOX, MSG, EMLX, HTML, vCal, vCard file formats. If you are not happy with the performance of this setup so you can return this utility within 30 days.
PST file Repair blog: How To Fix Outlook Error
OST file Repair tools: Manual Tricks to Convert OST file to PST file
