Fix OST file corruption and convert OST to PST file
eSoftTools OST to PST Converter Tool specially available to fix OST files even when OST file becomes corrupted or damaged by any reasons. By using this application, users easy to read OST email contents and other thinks without any restrictions. This tool comes with multiple conversion formats for ost file such as- Convert OST to PST, Office365, MBOX, EML, MSG, EMLX, HTML and VCF files.
The graphical interface is very clean and user-friendly that teaches itself how to open OST file and recover OST to PST file. If you want to split PST file from OST, then you can do it easily with the software because this tool offers PST splitting in various sizes.
Recover OST email by downloading this tool from
Get more info:
Convert OST to PST File
If you are facing the corruption for OST file and not able to resolve that problem then you can take help of the a blog which I am referring here to treat the OST file wisely and save it into PST format instantly. You can follow that OST to PST migration technique which allow the use to recover the data and convert it into PST format from OST.
ruchika
I would like to suggest you, try IGnissta OST Converter software Utility Program. This software is best and provide 100% Safe and secure results and it will take less time while ost to pst conversion. This software also support to convert multiple file format like: OST to PST, OST to Office 365, OST to MBOX, OST to EML, OST to MSG & OST to Vcard files.
# You can also Split Large OST file into Small Size PST file if Required
# You can Apply date Filter if you want to convert only few days, few month or few year
# Very Easy and Simple GUI which can easily understand for every one
Must Download & Install for Evaluation of Software Function
OST to PST Converter & Convert OST to PST File
Easy & Simple Steps:
Browse OST File -----------------> Preview Mails Item ----------------------> Export to PST
