daevenlate
Sometimes the user gets disturbed due to OST corruption problems and they have only one option for recovering their data. The last option is to convert the OST data into PST data file. If you searching for a trustworthy tool for the conversion purpose so we provide the best third-party tool that name is InQuit OST to PST Converter Software.
To recover data fastly use only InQuit OST to PST Recovery which quickly resolves all the problems of OST corruptions. Using this application you can not only recover your data but also convert into PST file format. By taking the help of this program user can convert the whole data such as emails, inbox, draft, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object and Time).
The interesting features
Convert multiple mailboxes: At a single time, the user can convert single as well as multiple files without losing any information.
Splitting option: It provides the file split facility to split mega-sized OST file into several small PST file as per your need.
Selective files: According to your choice you can select those file which you want to convert from OST file to newly created Outlook PST file.
Support multiple formats: The user can save their resultant files into PST, EML, EMLX, vCard, vCal, MSG,and MBOX file formats with full accuracy.
Office 365 & Live Exchange Server: It supports cloud-based application Office365 & live Exchange Server for containing the data.
Trustful and unique: The working performance of this tool such a great and it is very helpful for a novice user because to operate this there is no need of any technical skills this functionality makes it unique and advanced.
Supporting versions: it always supports all the version of MS Outlook 97, 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. Backing OS Windows version up to Win 10 (32 bit & 64 bit).
Display Preview: This utility shows the recovered mailbox before finishing the conversion of OST to PST and provides the correct result.
Best Price: Best feature IN Best Price
Conclusion
Using this wizard user can easily export their data into a new accessible PST file format. This program has a great capacity and it is very different from other software. According to users view it is one of the best. This assures the safety and security of valuable OST databases and makes it usable for further requirement. It provides a free demo version which allows you to transfer 30 emails per folder that is best for you to take the right Decision before paying money.
Read More OR Free Download Software: https://www.inquitsoftware.com/en/ost-to-pst-converter.html
Conclusion
