I want to delete "Found' folder on my partitions, it contains Found.XXXX folders that contain deleted files. The problem is that these folders contain deleted files with personal info in the filename and that I want removed. I was able to find with recovery software that there are ROOT\Found\Found.XXXX folders and I want to erase all such folders and files inside, on Windows 8.1 if I try to type D:\Found\ or to find me such folders, it says it couldn't find an existing folder with that name..
