ethanbrowns
Exchange mailbox recovery will be harsh if you lost your data due to any reason then you need to convert data from Exchange EDB to PST file format so use EDB to PST Converter application. Using it you can export single as well as more than one EDB file into PST and other amazing file formats like vCal, EML, MSG, EMLX, MBOX, and vCard with full accuracy.
You also convert the selected data which you want to convert and you can also make changes in the database but only before the conversion. It has a user-friendly interface that helps you to make your conversion smooth and reliable. The installation of MS Outlook is not required to convert email, draft, contact, sent item, delete item, attachment, notes and many more from EDB file to PST file format.
It gives you permission to export data directly into cloud-based application Office365 & Live Exchange Server. The performance of the tool make it one of the best and trustworthy tool among the users. You can easily export pub1edb and priv1edb file along with email, notes, contact, attachment and many more. The free demo version of the application give authority to export 30 emails per folder without any money. If you purchase this tool and you are not happy with its work, you can return it under 30 days without any difficulty.
Read More: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
