Free OST to PST Converter
Download eSoftTools free OST to PST Converter Software, It comes with a free trial edition of this tool in which users can convert 25 items of OST mailbox items into different formats. This software has a graphical user interface for all technical and non-technical clients. If clients are not satisfied with the software, users get a 30-day money-back guarantee. This tool has multiple methods to satisfy the clients like Mass Conversion, Email filtration option, multiple files option, etc. It supports all MS Outlook versions and Windows OS.
About Know More: Free OST to PST Converter
Ricky1
If you are looking for an error-free and affordable utility, You should try EmailsGuru OST to PST Converter, This software provides direct option to convert multiple OST files to PST format without data loss. You can directly convert OST emails, contacts. notes, calendars, journals, etc into PST format. The software retains meta properties of OST Emails such To, From, etc. It is fully compatible to support Microsoft Outlook 2019, 2016, 2013, 2010, etc. Technical support available for users for 24*7. Users can download free demo version of this tool.
If you are still looking for a solution to convert OST file to Outlook PST on Windows or Mac machine, you can download and run DRS OST to PST Converter Tool. The software has a capability to convert OST file and save to PST, and several other file formats including MSG, MBOX, EML, EMLX, PDF, HTML, etc. Furthermore, the software allows users to export OST to Office 365, Gmail, Yahoo, AOL, Zoho Mail, Yandex, etc. The software support both the Windows and Mac versions.
Thanks
ankittech
Still searching for a solution to convert OST file to Outlook PST, you can download Aryson OST to PST Converter. The software easily converts OST to PST with various other file formats and email clients. The tool allows users to preview the details of an OST file mailbox item and show the mailbox content in a tree-structure mode. Also, you can check the preview of your email items in a separate window.
Apply for Datavare OST to PST Converter and effortlessly convert OST data file to PST file format. The program allows swift and harmless conversion of OST files to PST files. With a few easy clicks, you can get OST mailbox data to PST format. Even no Outlook is required in the system for exporting OST emails to PST format. Not only email items but also contacts, calendars, notes, tasks, journals, etc. are securely exported from the OST file to Outlook PST format.
For the fastest migration of OST file, You can use this outstanding Softaken OST to PST Converter Software, give you the instant right to use from your damaged OST file as well as all users capable to open OST file items into multiple formats such as PST, EML, MBOX, MSG, vCard, EMLX, file formats, with simply transfer all OST mailbox folders items and meta properties, etc.
if you find the free OST to PST converter tool so you need to download CloudMigration OST to PST Converter Tool. . This is the best tool to convert OST files in any file format like- PST, MBOX, EML, etc. There are many different features such as:- it's compatible with all windows versions. It exports OST files without attachments. You can split your PST file with this tool, etc. This tool provides a free demo version for the new users so you can try it.
Ricky1
If You are searching a free OST to PST Converter then You are at right place, You can try EmailsGuru OST to PST Converter for an error-free and effortless solution to convert single or multiple OST files to PST format. You can even convert OST emails, contacts, notes, calendars,, journals, etc. This tool keep maintain meta properties of OST emails even after the conversion from OST to PST. It is fully compatible to support all editions of Microsoft Outlook.
MigrateEmails OST to PST Converter tool is the best option for converting OST files to PST . This is a professional software that allows users to transfer OST files into different other file formats and email clients. It has advanced features through which you can have a precise result. Many users have got benefit from it, you can also take help from this expert tool and complete your task .To check its accuracy, you can download its free trial version and convert 50 emails per folder for free.
To know the manual technique read this blog - Visit - How to Change OST to PST Format? Complete Guide
I will advise you try GainTools OST to PST Converter Tool. To convert OST data into PST file format users can migrate the whole data from offline OST file to Outlook PST file format. Before the migration it shows the preview of change mailbox included with email, draft, task, attachment, notes, contact, calendar and journals etc. then stores the data into PST and other file formats like EML, EMLX, vCard, vCal, MSG, and MBOX. It supports MS Outlook version 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019.
OST to PST Converter program allows users to export the whole contents of an OST file and reopen it in a new PST file. It also recovers OST file data, as well as entire damaged Outlook OST email items, including inbox, outbox, sent mail, notes, tasks, journals, and drafts, among others. You can also save OST data in PST format with this program. It also works with all versions of MS Outlook, including 2007, 2010, 2013, 2016, and 2019. This tool is also compatible with all versions of the Windows operating system.
AnkitAryson
Try MacSonik OST to PST Converter to risk-free convert OST to PST files with attachments. It is the most recommended and trusted professional solution to convert and migrate OST files into 20+ file formats and email clients without any data alteration. Users can set the custom folder name and the location of the resultant file prior to the conversion process. This OST to PST Converter for Mac also allows the users to quickly remove duplicate emails from the conversion process without any hassle.
Danish
OST to PST Migration Tool is the best tool to Convert/Migrate OST to Outlook PST files. This tool can convert single as well as multiple OST files ar a time. It also provides a very user-friendly interface that helps users for easy conversion.
