Hey,
I feel your pain. The manual method for converting NSF to PST is notoriously difficult and often fails, especially with larger mailboxes. It's just not a reliable process.
You can save yourself a lot of time and frustration by using a dedicated converter. I suggest you try the eSoftTools NSF to PST Converter. It automates the entire process and is designed to handle the complexities of conversion without any errors or data loss.
You simply select your NSF file, choose the conversion options, and the software does the rest. It's a 'fire and forget' solution that just works. It's well worth it to avoid the headache of manual conversion.
Read More - Best NSF to PST Converter Software
