I have had a problem with Eraser v6.0.8 running on XP Pro SP3 32bit.
Here's what happened.
- cut then pasted all files on an external storage USB Iomega 300G HD to the computer drive, so the external drive is then empty.
- ran Erase Free Space of the external drive using Guttman 35 passes using pseudorandom.
- at the very end, Eraser would not finish. The progress bar showed all tick marks to the very end, but it just kept running, never completing.
- I ended Eraser, but had to do so with Task Manager.
- I checked inside the external drive and a randomly named folder was there. I opened this but the Windows flashlight searching animation happened and kept going. I checked Properties for this folder and the dialog showed 27,000 files and continuing to climb (oddly, it said it was 0 bytes in size, btw). I couldn't end this box as the file count continued to climb and ended up shutting down and restarting the machine.
- After restart, I deleted the randomly named folder on the external drive, which took about 20 minutes.
- after this delete, the system says this external drive is 298G in size and that it now has 281G of free space.
My main questions are:
- is the external drive now erased of all the data I cut pasted from it at my first step above?
- what happened here and what should I do, if anything?
I should add that I did an identical free space erase on another external drive the day before (after cut pasting as above; this 300G was also full like above), and Eraser completed it with none of the issues described above, although the report in Eraser did say "completed with errors". It also had the folder of randomly named files afterwards but, in this case, when I deleted it, it deleted quickly. Not like the 20 minutes above. I was able to open it to see lots of randomly named files.
Thanks.
Thanks.
