daevenlate
BIGGEST OFFER ON ALL PRODUCTS OF INQUIT SOFTWARE
30% OFF Instant Discount on every product - Use Coupon Code: INQUIT30OFFER
If you have tried many software to recover your Exchange EDB data and not satisfied with its performance I would like to advise you to try InQuit EDB to PST Converter application that is made up by using the rich algorithm and the best technology. The interesting features of this program make it smart and unique from other software.
The admirable features
Convert data from EDB file to PST file: At a one time, you convert your data from Exchange EDB file to Outlook PST file format without any hassle.
Supported version: This tool always supports all the version of MS Outlook version 98, 2000, 2002, 2003, 2007, 2010, 2013, 2016 and 2019. It support Windows version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).
Convert more than one file: This application will allow you to convert one as well as more than one file along with all the data of EDB mailbox.
Saving format: This setup gives you permission to export your data into several interesting file formats like PST, EML, EMLX, MSG, HTML, vCal, vCard, and MBOX.
30 days money-back guarantee: If you are not happy with its performance then you return it under 30 days without facing any trouble.
Read more info: https://www.inquitsoftware.com
