shivamsaini55
If you have Exchange Database (EDB) files and need to convert them to PDF online, you can follow this process:
This method is a manual way to convert EDB files to PDF. However, for a more streamlined process, using a specialized software utility may be required. One such reliable tool is Goldytools EDB to PDF Converter, which provides a quick and efficient solution for converting EDB files to PDF.
- Open Outlook and log in with your credentials.
- Select the "File" option, then click on "Options."
- In the Outlook options, go to the "Add-ins" section.
- From the drop-down menu for Com Add-ins, click the "Go" button.
- In the Com Add-ins window, check the box for "Acrobat PDFMaker Add-in" to enable it.
- Finally, select the messages or folder that you want to convert into PDF.
