Replication problems in Lotus Notes can lead to missing or duplicated data, often caused by synchronization failures or inconsistencies between local and server copies. You can manually trigger replication by using the "Replicate Now" option in the Notes client. If the issue persists, running maintenance tools like Fixup, Updall, and Compact can help. However, if replication errors continue, converting NSF files to PST can be an effective solution to migrate data without errors. eSoftTools NSF to PST Converter Software ensures a smooth transfer of emails, contacts, and calendars while maintaining the folder hierarchy and data integrity.
Read More:- fix replication issues in Lotus Notes
