How Convert ANSI to Unicode PST to Access ANSI PST of Unlimited size In Recent Outlook Versions?
terryherrera
ANSI is the format of PST file in earlier versions of Outlook (2000, 2002, 97) and Unicode is the PST format of recent Versions of Outlook. ANSI PST has a size limit of 2GB and it is accessible in recent versions of Outlook but, when you access ANSI PST in recent versions, the size limit of PST file remains the same. There are many chances of corruption and damage in ANSI PST file in situations when, it reaches or exceeds its size and there are very less chances of corruption and damage in Unicode PST file as there is no size limit of PST file in Unicode format, Unicode PST can grow unlimited. The Outlook versions which support Unicode PST are much faster and better as they provide better interface, high performance and many features. After, ANSI to Unicode conversion, you can easily open ANSI PST as Unicode PST in all the recent versions of Outlook for better experience. Recent versions of Outlook also provide advanced scheduling of emails.
ANSI to Unicode conversion is beneficial in many ways and to convert ANSI to Unicode PST a commercial tool is the effective solution. There are many commercial tools to convert ANSI to Unicode PST efficiently but, PST Upgrade software is a complete package in low price. This software can perform both upgradation of PST from ANSI to Unicode and degradation from Unicode PST to ANSI PST. This software doesn’t make changes to the properties of ANSI PST while converting it from ANSI PST to Unicode PST and it functions smoothly in all the editions of Windows.
Download Free Software from here and upgrade Outlook ANSI PST to Unicode PST Upgrade PST Pro is PST Upgrade tool to Convert ANSI to Unicode
