smithjones24
There are two ways to convert OLM to PST, either manually and professionally. First, for the manual method, you create an IMAP email account (Ex. Gmail) and set that up in Outlook for Mac and Outlook for Windows. You initially need to sync up your OLM data (emails, contacts, etc.) into the IMAP account on Mac, then you need to access the IMAP account in Outlook on Windows and export that data as a PST file.
The manual method can be tedious, technical, and presumably it can separate two devices and/or service providers. The manual method does not provide a direct route from OLM to PST and you run a high risk of losing data or migrating it partially (possibly missing knowledge levels too), especially if you have a very large or complex mailbox.
If you're looking for a stress-free experience, it is best to go with the MigrateEmails OLM to PST Converter Tool. This is a highly-efficient utilization that has many advanced features for converting your OLM file format to PST. In addition, it helps to keep your data secured with no file size limitations. Make sure you look through all of the advanced filters to use this tool smoothly.
Basic steps to convert OLM to PST:
1. First of all download and install MigrateEmails OLM Converter Tool.
2. Select Single File or Multiple Files/Folders & add OLM file >> Next.
3. Then Preview & select the files/folders and click Next.
4. Select Saving format as PST from the list.
5. Now apply advanced features per your requirements.
6. In the last provide location to save & click on Convert.
