camilia
Download Advance & recently added Unique Features tool of KDETools for OST to PST Converter software. The software to fixes corruption, errors and etc. negative issues of offline OST files easily. It application deeply scans large size of offline OST files to remove password-protections problems in only one shot with 100% safe your internal OST files database. By using its utility you can convert OST to PST Outlook format including also manage according to outlook users can smoothly multiple file format such as- PST, Zimbra, Gmail, Office 365, MBOX, Live Exchange Server, EML, EMLX, MSG, vCard, ICS, and etc.
Steps- :
“Run” Lunched KDETools for OST to PST Software.
Go to OST > "File/Folder".
"Preview" > OST Files> Conversion Data.
Open > click "Export".
Export Option > "Select PST File" > Next.
Select > "Split Option" > Manage PST Files Size > 1GB /25GB.
Select > "Messages Filtering Option" > Date/Contacts/Size and etc.
Then select another option -> Outlook Data File (.pst) and then click Next.
After which select the folder which you want to export and click Next.
Browse the location where you want to save the new PST file.
More Info- Convert OST to PST Outlook
Steps- :
