Using Softaken EDB to PST Converter, it's easy to get a mailbox out of an EDB file. The program will scan the EDB file and load all the mailboxes it finds. You can see what's in each mailbox, like emails, contacts, calendars, notes, and more. Choose PST as the export format when you choose the exact mailbox or mailboxes you want to extract. You can also use filters to export only certain folders or objects based on their date or category. Please set the destination path for the output PST file and initiate the export process once everything is prepared. It supports all major Exchange versions from 2003 to 2019 and works on all modern Windows platforms.
Talk to ChatGPT
Talk to ChatGPT
