HenryBlackk
After exporting your OST emails to MSG, if you encounter formatting issues, you will need to check the export settings and the application you are viewing the files in order to identify the issue. If users use TrustVare OST to MSG Converter all formatting such as inline images, fonts, hyperlinks, and layout is automatically preserved as set in your original emails. If when you open the exported MSG file, you note that formatting is still an issue, consider troubleshooting by checking the original OST file to see if it is corrupted and try re exporting the problem emails. You also want to confirm you have opened the MSG files with an Outlook version that matches the version you were using to export, as outdated versions or restrictions could cause formatting issues. If you still experience issues, try converting a small sample of emails again to your desired file format using different view settings to determine which view works best for your layout.
