smithjones24
To troubleshoot the Kindle E999 error manually, simply press and hold the power key for about 40 seconds (or until the screen automatically shuts down), then release the power key to restart your Kindle. When it powers back on, ensure that the battery has sufficient charge and your device is connected to stable Wi-Fi. If you continue to receive the Kindle E999 error, try to deregister and then re-register your Kindle through the settings option.
There, of course, are limits to manual troubleshooting. If the error is a result of corrupted firmware or if there is an internal hardware issue, the solution is to contact Kindle support or perform a factory reset.
If you are concerned about the data for your Kindle being erased, I encourage you to back up your data. The MacSonik EPUB Converter tool can help you do so by converting EPUB files into PDF, DOC, JPEG, as well as 10+ other formats as well as providing the original folder structure of the book; it even supports multiple EPUB at once so you can speed up the conversion and stay organized while backing up in large volumes. And, it does so while keeping the integrity of the data clear throughout the backing up process.
Backing Up Your Kindle (EPUB):
1. Open the MacSonik EPUB Converter program on your device.
2. Import or upload your EPUB files.
3. Select PDF for your output format.
4. Select a folder to save your files to.
5. Click convert
5. Click convert
